That's the UCH inhibiting the vehicle starting because of a fault. Most Common on the 1.2 is either the keyfob itself, the decoder ring or, get ready for it, the UCH itself is faulty and they're about £380-400 from me to supply and code up and Renault are a fair bit more.
As mentioned above you really need the vehicle plugging in to CLIP now to see what exactly is causing the LED to remain lit. You can try other bits of kit if you like but most aftermarket kit struggles with the Renault security protocols even some of the newer SnapOn kit like the Ethos and Vantage.
Mick
