Clio 1.2: Toe and Camber settings
Car  Clio 1.2 Dynamique
Hi,
I have had coilovers fitted to my 1.2 clio 03 plate, and I now need the tracking and camber adjusted. The coilovers have adjustable camber with the bolts at the bottom of the strut.
However, I can not seem to find what the camber should be as standard on the clio to get it setup correctly.
Any ideas?
Thanks.
i think you might find it difficult to find the camber settings for it, what you could do seeming as you are lower and stiffer is to try the settings for the sport ?
i'm sure someone will be along to correct me if i'm wrong :)
