clio 100 TCE 5door (the older one) weigth to use (kerb or gross)?
  AB182, Audi A5 3.0
trying to get the correct weight to put into Torque, should i be uisng the 'Kerb Weight' or 'Gross vehicle weight'? Whats the difference between these two?!
  AB182, Audi A5 3.0
are you sure? how can they give a weight for that on specifications if all people are differnt weights?!
Knuckles
ClioSport Admin
Straight from the Renault towing guide
  53 Clio's & counting
Gross weight is the maximum the car should weigh with whatever it has inside it - ie the combined weight of the car itself, with all contence, an example being if you need to carry some big stones and they weigh 50kg's each, you can work out how much you can carry by taking the gross weight of the car, adding your weight then adding the weight of each stone until you reach the gross weight.
