clio 172 24k service
Car  VW Potato
hy peeps,
hope youre all well. Pls, what do you get for a 24k (at 24k) service on a 172? Im assuming brake fluid change, levels topped up, oil + filter, air filter, pollen filter. How long do the plugs last? Are they 60k plugs or will they need changing at 24k? If theres anything Ive missed, pls could you say.
Is there anything that its advisable to check at 24k on a Clio (i dunno, tracking, emissions, or something??)
cheers!
g
The plugs last for ages as they are precious metal ones.. (a.k.a. f**king expensive when you do have to change them !!)
Nope I think you covered everything, make sure you water bottle for the screen is topped up otherwise they will charge you for that too.
ok, tops! thanks KDF. My dads garage will do it, not Renault. Altough he can get the service schedule, i just wanted to check if there was anything beyond the bleedin obvious he should know about in advance. That reminds me - he can check what I think is a slight clonking from the nearside front...
g
