Mine does this if you tap the thottle on over run when it's cold, as tomhunt85 said with regards the remap I've read and spoke to many owners that say that the RStuner software helps with cold run in the the fact it slightly raises cold idle iirc
It could also be an injector on the way out. If it get worse it's obviously not the map and you should see a flashing engine light in the bottom right of the dash.
Mines really bad for it when I'm part throttle at low revs during cold start, feels like it's holding back, pops and farts on overrun too. If I give it full throttle a few times or wait a minute or so it will suddenly "clear" and be fine. Think it's just how it is
