hi mates
I have a clio 172, the engine runs fine but will not start.
Has fuel, pump is okay, but no energy in the coil cables / plugs.
crankshaft sensor is new.
What else can it be?
when you put the key in the ignition and turn the key does the engine turn over ? does the led in the insturment panel flash when cranking over ?
Have you checked the +ve connection to the coil pack (inside the plug, 3rd metal pin). Is it getting 12V?
If so - do you have a spark at the coilpack end (to test- remove a lead and rest it close to the top of the coilpack - you should be able to see it sparking when cranking). If you have a spark then check the plug end of the lead for a spark.
If not then its a wiring issue between the battery and the coil pack connector.
Hope this helps.
I have 12v at the 3rd pin of the plug coil
