clio 172 ph2 shift light wiring
Car  Clio 172
Evening,
I'm trying to wire in a Gizmo dual stage shift light.
I've wired the positive and earth into the instrument cluster wiring loom but I'm struggling to find the correct wire for the tacho signal.
I first tried the tacho signal for the instrument cluster but that just made the light constantly flicker. next up i tried the white wire on the coil pack connector but that just made the light stay on.
The instructions say to connect it to the :
taco signal, ignition coil negative or igniter trigger wire.
I've searched the forums but mainly info is about the factory fitted shift indicator
