Hi guys,
on my clio 172 ph2 I have bad sluggish starts when hot (or little warm) and when I wait 10minutes or more. The more I wait the start is worse. When I turn off hot engine and try to start immediately (or until 10 mins), everything is ok, but when I wait 1-2 hours it must crank for 10secs or I give it next try. When is cold everything's ok.
No faults on diagnostic.
Sent injectors for diagnostic and cleanup, one was faulty so I bought new and then all four was ok on tests (seal test, splash, resistrance etc.).
Changed air temp sensor, front (up) lambda sensor, plugs.
Cleaning throttle body and tdc help me a little (I was able to wait 20 minutes without symptomps) for while, but after one track day is it same as before.
Thanks for advice and greetings from Czech republic.
