Noticed my temperature gauge was reading maximum, stopped the car and all the fluid had been dropped out of the cooling system.
Massive amounts leaking from drivers side of car, from the area behind the wheel well. Below the alternator area. The car has air con so access is even more restricted but I assume this is where the water pump is? The previous owner had the cambelt changed about 1000 miles ago so I'm pretty pissed that they didn't do the pump at the same time! Anyone got a guide for replacing the water pump on it's own, or any suggestions of what else it could be in that area? It's literally dropping the entire contents of the cooling system in around 2 minutes, so it's a big b*****d leak!
