Clio 182 door removal help
  Yozza'd Titanium 182
I'm currently in the process of breaking my 182.
How easy is it to remove the whole door from the car?
Has anyone done this before? Any tips or tools I need?
  Clio 2.0 16v 182
T50? Torx piece, Hammer and pin punch. A jack and something to lean it on once it's off. Torx bolt first. Then wires. Then the pin hinges. Get the window rolled down so you can hold it easier.
  330i. E30 Touring.
If you're breaking a car, and this is stumping you then you shouldn't be breaking a car.
Iv taken pretty much everything else off..?
Done disks pads, suspension, full clio replica in the past, seats, Remap, decat and yozza change, replaced electric window motor..
Just wanted a bit of advice on the pin thing really
  Clio 2.0 16v 182
I think it's T50 but there's one bracing hinge that need to be unbolted using a torx piece. And two main pivot hinges that need to have the pins beaten out. These two are a pain to get to and awkward to remove. It also helps if you have another set of hands to help
