Clio 182 Driveshaft
Car  Clio 182
Apologises if this has been covered before but is there any difference between a non cup and cup drivers side driveshaft apart from the width of the abs ring, and the part number?
phs 2 182 cup chassis
passenger 8200372167
driver 8200372166
phs 2 182 non cup
passenger 8200352043
driver 8200352042
There a different length, if it was just a case of the abs rings being wider on the cup then they could of just used the same on non cup.
driver 8200372166
phs 2 182 non cup
driver 8200352042
The cup wheel bearing is 84od x 39id x 40width in mm, and the standard 182 is 72 x 37 x 37, so the CV`s are sized to fit.
I love this stuff.
Did you know that the spherical bearing on the lower end of a Yamaha DT125R rear shock, which is not serviced, is exactly the same as the one in a Kawasaki Z550 H2 rising rate unitrak link arm, which is.
@imprezaworks
Thank you. The reason I asked is that my garage replaced the driver side shaft on my 182 with Cup pack suspension, with a GKN item part number 304798 looking this up on the web it looks like a std 182 oe part number 8200352042. There is the ABS rumble when braking under 5mph but otherwise seems fine!
They should of played spot the difference when they fitted it?
All the old news hear
http://www.cliosport.net/threads/driveshaft-problems.424018/
