Clio 182 idle speed fluctuation,help need ,please.
Car  Clio 182
Hi.
A I have an annoying idle fault. My Clio(182) if the engine cold(only this time) and the car is rolling the gearshift is N so just rolling the idle go up and down 2 times and then normal ~1000 rmp when cold.The engine when warm everything is ok(and don't jumping the idle rmp). If the car is stand the idle perfect any-time.
The Tbody is clean and had a new packing ring. The map sensor new and the Temp sensor too
what can i do?
I have a video this situation:
[video]http://videa.hu/videok/jarmuvek/clio-182-alapjarat-TB7ykZiwd0Xeoy5R?play=1[/video]
Mine does this but not as bad, is fine when its warmed up a little , they are notoriously bad when cold, and TBH the problem has never bothered me only lasts for about 2 mins.
Mine does similar when stone cold but not to that extent, maybe hunts 2 or 3 times before settling at the cold idle speed.
If its ok after a few minutes I wouldn't worry.
