Clio 182 speedometer accuracy?
mine seems to give a greater error at low speed say about 5-10% and when i get to about 70 -80 mph the accuracy when comapred with road angel speed is very good say about 2-3% out. readings are always slower than the road angel. i've not really looked to see if it goes the other way when above 90 say as i havent driven that fast ;P
have you noticed how the dial and the cruise control don't match up? If I set 70 mph on the cruise control, the dial reads over 70.
Yep, sure have. Strange...
Its a bit disconcerting in some ways as if yor using the cruise control to control your speed (like i sometimes do), i'm always slightly uncertain as to whether i should trust the speed the cruise is saying i'm doing or whether i should trust the dial...
i believe the cruise control is more accurate than the dial as my cruise displays the same speed as the gps
On mine the speed set on the cruise control is exactly the same as the road angel (GPS), at 70mph on the road angel and crusie control the speedo normall reads 72/73mph
it's a bit jobby though, ain't it. you would have thought they would both work off the same sensor. French electrics!
does anyone elses speedo not really work at really low speeds? say like it wont move when your going along at 5mph, only really picks up above 10-15?
should i take it into the garage?
i set my cc at 50 in a 50 limit..and went past a speed detector which flashed at me for going over 50. strange!
I've got the same problem on my new 182, I find myself going by the dial and when I have the cruise on I might have to set it at slightly slower speed for speed camera etc....... does this happen on every 182?
the cruise control is the more acurate reading, tolerances in speedo's are allowed which is why you get the 10% off mr policeman.
its impossible for a 100% acurate speedo due to the differences you can have in tyre treads from 8mm to 1.6mm, the cruise control uses the engine ecu info so is the acurate one.
ive got 2 gps systems (navam and road angel) and say if the car speedometer is 50 then they both read 48....quite good.
in my old mg there used to be 4 or even 5 mph difference.
when im at 70mph my sat nav (avic-x1) reads 66-67mph! took it to 120mph on the speedo and it read 113-114mph? so mines out too...
oh and the cc is almost spot on every time!
on the cruise control digital speedo bit, according to my tom tom gps, mine is 1mph too fast.
the anologue gauge is an extra 1-2mph too fast.
i had a speedo changed under warranty for the cc speed to be out on the speedo.
It was better when changed, not as bad..
On mine:
50 mph on Cruise = 50 Mph on Road Angel, Speedo shows 52/53
70 mph on Cruise = 69 Mph on Road Angel, Speedo shows 73/74
does anybody know about this? ^^^^^
Are you reffering to those signs which say "your speed" blah blah?
If you're talking about an actual camera this seems very unlikely as speed cameras are set to trigger at 10% + 2mph i.e. 50mph = 50mph + 10% (5mph) + 2mph so it would only trigger at 57mph.
I'd be MUCH more inclined to trust the GPS speed as this is =>99% accurate. it's calculated by distance in relation to your longitude and latitude and is a hell of a lot more accurate than the speedo which i believe is linked to your gearbox.
The syncro on my gearbox is way out and my speedo reads 36mph when im actually doing 30mph (counter balanced now by my alloy wheels 3mph out now).
Around my area (Northumberland) we have alot of signs around schools which have "your speed XX" they flash when you're doing even 1mph over the limit. These all read the exact same as my TomTom and my brothers RoadAngel. I'd be more inclined to believe them as there also placed around speed cameras in my area.
