Clio 197 change (lengthen) 6th gear
  clio rs
I own a late 2006 Clio 197 and I want to change (lengthen) the 6th gear since it's very noisy at the motorway.
I was told it'a very simple procedure and that I only need a new pair set of gears
After 2008 it was improved from 18,9 to 20,36 mph using 6th gear at 1000 rpm, meaning that it takes 300rpm less to travel with a speed of 80 mph.
Eventhough I would prefer to lenghten it a bit more, does anybody know the part no (if there is any) or a can provide a drawing for the new gear set ?
P.S. I'd rather avoid the official dealer since I'm certain it will cost me a fortune
Thanks in advance
This is a popular mod on a not clio forum I'm on. Not sure if you can get to the gear in the clio like you can in other cars though? If you can then it is simple enough
  clio rs
First of all I wish to thank you both for your replies
Can you PM me/post the details, so I can look for some more info ?
The guy from my service garage informed me that it's an easy procedure. The issue is that 6gear clios aren't that popular and he doesn't have the parts ( set of gears), eventhough he has many spare gears for the 5gear clios.
This is why I'm looking for more information in order to purchase them and make sure the'll fit
Thank you !
