CLIO 197 ECU NEEDED HELP!!
  renault clio 197
HI, WENT TO START THE CLIO THIS MORNING AND NO GO!
HAD IT LOOKED AND AND ECU HAS BURNT OUT
NEED A ECU, ANY HELP OR SUGGESTIONS WOULD BE MUCH APPRICIATED
THANKS
  Renault Clio182 bean
Contact a company called 'BBA -Reman' they are very good at what they do and will be able to look at your current ECU and make a decision whether it can be repaired or not, they should be able to supply a new one if its not repairable :) and should be much cheaper than the dealers
Alastair.
  986'S 172ph1+182FF
Won't be the injection computer unless you've connected the battery around the wrong way.
  renault clio 197
cheers snake182 will give them a call,
