Mk2 Phase 2 Clio 1.6 16v
Hello guys, have had BMW's and Volkwagens in the past, whenever I've had engine trouble at idle its usually been down to coil packs and the mass air flow sensor. I just bought my girlfriend a clio yesterday evening, its a tidy little motor. However when the engine is warm, it seems to just cut out intermittently at idle, not when in transit, just at low revs/idle. When you start it there doesn't seem to be more than a 100 revs at idle, but this morning I got in, gave it a cold start and all was fine, was idling at about 800rpm. I've ordered a set of 4 ignition coils off ebay for the bargain price of £44 and wanted to get a mass air flow sensor as well, I cant seem to figure out where the part is on the engine though let alone locate one on ebay. Could you help me out, any help is appreciated, especially if you've came across this problem before. Also the car has done 58,000 miles but I cannot see any records of a cam belt change, would you advise this also? Cheers guys, much appreciated.
