Clio 200 esp check light ?
  Clio 200 full fat
Hey guys need some help the other day while In traffic my esp light came on so I turned the car on and off the light went away today the same thing happend checked the abs rings they seem ok as do the cable any one else had this
thanks terry
ForceIndia
  Gentlemans spec 200
As above. I'd hook a code reader/rs tuner up. Having a similar issue with out dci175. Code reader suggests it's a faulty throttle or brake position sensor.
  Clio 200 full fat
Have you checked the brake fluid level mate ?
ive checked this the brake fluid is full also checked the pads there ok and the sensors look ok the light only came up that time last week and last night but once the car is turned off it never comes back on
  Clio 200 full fat
Brake switch is my bet. Get it plugged in.
That's what I thought Alex got it on the machine at the garage next door and came back with this Df126 control panel sensor information plaues abillty so it's throttle related and because it only once in a blue thought it can't be the pedal so I checked the throttle body and it was filthy and cleaned it car is now running smother and feels little bit more power :)
