Hi all, I come to you at the end of my teather so please excuse the abrupt nature of this post.
I bought a 2006 Clio recently 1.4 16v it was cheap as it needed the head gasket doing. Not a problem, it started and drove and didn't boil up so I bought it and replaced the head gasket, timing belt, all pulleys and water pump.
Came to put it all back together (I've timed it correctly using the correct cam locking tools and crank locking tools) turned over by hand totally fine.
Put the battery back on, turned the key....nothing.
Dash lights up, and that's it, no clicks at the starter motor, nothing.
Here's what I've tried so far after googling and browsing this forum for almost 2 weeks.
1) checked all fuses, all fine.
2) checked tdc sensor for resistance and cleaned it.
3) put on a new battery
4) checked under battery box for visibly broken wires
5) checked white starter motor signal wire.
6) tried spare key
7) tried the imobbiliser reset trick with the doors open etc...
All of the above results in the same issue, turn key, dash lights up, red imobbiliser light goes solid, one beep from dash, engine does not crank.
I'm at my Witt's end....any suggestions at all?
Or anyone in the Leeds area LS10 who has a Renault CLIP device I'll happily pay you to come and plug it in a diagnose for me.
Please get in touch.
6) tried spare key
