Clio 4 speed Gearbox
Car  Oyster Card
What do you make of them, it's a 1.2 Oasis RL. Lovely condition with just under 60k on the clock.
I was wondering I'm currently driving a 5 speed Clio (Well half of one if you've been following my crash thread)
I was wondering does only having four gears hamper speed/mpg at all?
Im guessing and hoping the gear ratio has been altered to allow for basically the same mpg as the 5 speed?
The ratios are often a bit shoter and a mid range so your top gear in a 4 speed is just between the 4th and 5th gear in a 5 speed box. A 5 speed box will get better acceletaion and mpg but its only small and you won't usually notice it.
nope lunner your wrong, oasis came in all sorts, my 1.2 is an oasis 3 door, the 1.2 i had beforwe was an oasis 3 door 4gear
