The ones that are through the edge of the bumper into the archliner?m6 x 12mm fwir but anything around that will do.
Think you're right for the ones on the brackets mate!sorry, my bad. long island iced tea in a pint glass doesn't help concentration ?
I don't run the bolts in the brackets for the bumper but I run all the bolts that hold in the arch liners to the bumper.You honestly don't need them on a Mk2. I never ran them on mine and I know the likes of @Budgie if he's still around on here never did either.
But then you have holes in the bumper edge which looks messy and archliners free to move slightly. They'd still be held in with fir clips howeverI never ran a single bolt on my front bumper. I just had those press studs in the top of the grill.
Just tug the bumper, hard. The brackets on the bumper dont have rounded holes they're just 'forks' if that makes sense.
You'll be able to get better access to remove the bolts when you remove the bumper.
Yeah makes sense now that, I managed to unbolt one side and thought balls I've made a right mess of that only to realise it's a 'fork' in the plastic ans supposed to be like that doh!
On a sort of related note, I couldn't get the slam panel off either! I couldn't get access to the 2 lower bolts because of the Rad being in the way, no way could a spanner/socket fit in the gap due to the Rad.
You only need to loosen the 2 for the slam panel mate. The panel is slotted, so once it's loose it just lifts up. A ring or ratchet spanner will do it.
I must have missed something because I undid the top 2 bolts - near the bonnet catch and I couldn't move it!
Like I said before I managed to do the job with the bumper and slam panel still on but life would have been much easier with them off!
I just wanted to know the reasons why I couldn't remove them, still bugs me now!!
I didnt mate no. I need to revisit this.Old bump but did you find some stainless screws mate,i want to do mine also.As like you say ebay ones just rust so quick @Louis
