Quote: Originally posted by mjdymond on 25 September 2004
when do u think tuning boxes and chips will start to come out for the dci 100? I have looked hard and cant seem to find anything out there. I was under the impression it has uprated turbo pistons and intercooler to the dci 85 so should be able to be tuned a fair bit 130-140bhp maybe?
The 100 has better (read better piston for the heat) plus diffferent bearings plus uprated oil coler and oil jets. To make more hp though its just an uping of the boost (new turbo) for 1.25bar (overbust to 1.4 bar I think) boost plus bigger intercooler (I think) plus bigger injectors and pump (most likly). Also the engine has abetter box for the torque.
Assuming the boost isnt fiddled with then 125~130hp is possible with tunning boxes and maybe a few hp more with a remap but power delivery will be better.
Not heard of any tunning work on they yet there to expensive for people do much to them at the monentin my view. You could ring superchip they have cracked the ecu programming so will make you one and make it just for your car if youd agree to be the test subject as such most likly.
Stock 65 and 80hp tunning boxes probably will work bno problem so long as they dont push the fueling level to far.
How much torque you get is a bit of a juestion the stock car is limited to 200NM maybe so it doesnt beat the 182 or maybe cos the box cannot take loads more or maybe cos the engine cannot take any more.
Assuming thy limit torque as to let the 182 be just as good or to give a nice flat torque curve then you could get around 220lb torque. I have the turbo code somewhere but without having the maps and knowing what the engine and injectors can make it is usless.
