scotiamr2t
Mazda 2, Ph1 172
A more than likely out of the ordinary question but I am looking for the below so I can make a new clutch hard line to fit a DCI pedal box
I need the push fitting that goes into the clutch master cylinder but converts it to an AN-4 hose fitting, a bit like the fittings earls do but with the Renault profile.
Anyone any idea where I could find such a fitting?
Link to earls fitting below
www.holley.com
Earl's 652504ERL Earl's Clutch Adapter Fitting - Late
The clutch system on most late-model vehicles use a plastic clutch hose that is tough to modify when doing an engine swap. The OE plastic hose can expand and may not work correctly in high heat, high pressure, or with a racing clutch. These special stainless steel adapter fittings works with...
