clio dCi Dynamique
I have a 2007 clio dci 80 dynamique, 3 door.
recently i had water spilling in to the passenger foot well, i could hear water splashing about from inside the dash when i drove. I eventually found and cleared the drain holes below the wipers and all water now clears.
I now have no working blower, fan does not blow.
With the heater on i can feel it heating up so assume it is working and its not just the engine heat heating it up (?).
Dashheater illumination is intermittent as dials are moved.
Turning the fan on from 0-1 (and up to 4) i can hear a relay click behind the glove box.
Removing the 5 pin connector from the fan unit itself i can measure 15vdc at pins 1,3 and 5 when the fan is switched on.
With power to the fan i assume the fuses are fine. i would check the fuses but i cannot reach the upper ones behind the steering column without removing the the dash.
I'm thinking the fan motor has been water damaged and i will need a new motor and fan assembly.
I have a haynes manual on route but thought i'd ask the forum for advice.
thanks in advance for any help on this.
