With the greatest respect - Why would you bother ?
You've essentially got a set of components up front... You don't watch your TV facing the other way !? Why would you want sound coming from behind you...
I know this is bringing back a VERY old post, but I am looking to add rear speakers to my clio campus and would find pictures/ instructions helpfulIf you've not done that kind of thing before can be quite tricky.
Just get some speaker wire, pull of rear speaker covers. Lay wire down side of car, behind plastic on the sides. Pull off door seal rubbers so you can tuck it in.
Then take it up to the headunit, and you'll have two iso blocks. One is power, the other is speaker. You'll need to bunnyhop the +/- for each side to the two outside wires on each side of the speaker half of the iso blocks at the back of the headunit.
As per sensible posts above, don't.
If you have an upgraded headunit, spend money on a small, under-seat sub instead. The stock front components are quite decent when you set your stereo to not send bass to them.
:up:
Entirely personal.So you think that an undeseat sub would be the way to go? I have been trying to make a decision between a ported boot sub or a sub like this: https://www.amazon.co.uk/dp/B00BO8O9XQ/?tag=cliospnet01-21
opinions please :smile:
