Quote: Originally posted by hip_spasm on 04 July 2004
Heard someone somewhere (not on here) whining that the paint on the door edges was too THIN and came off far too easily if the door edge took a knock (on another car for instance)
Any thoughts? I know I ruined my door edges on brick walls.......
The problem is, if you try to get a good covering on the edge of a panel, due to the nature of the paint while still wet, it will more than likely result in a run which is even less acceptable to a consumer than a thin coat of paint.
My advice would be to not park too close to brick walls!
Mat.
