t3 corolla 116bhp
hi all
at present i have a problem with the aux drive belt in my clio. it was only fitted bout 3wks ago and is due a re-tighten
however, shortly after the old one was replaced, i have noticed an intermittent noise which sounds like a vibration/humming.
couple of points to note:
1) the noise is usually only present when the engine starts from cold and is fairly intermittent. by the time the engine has got up to operating temp for 5 mins or so, the noise disappears.
2) when i rotate the steering wheel on full lock both directions (if that makes sense), the noise seems to go (or get quieter/becomes interrupted) until i stop turning the wheel. once the wheel is on full lock, sometimes the noise is gone, other times its there slightly.
i cant manage to hear the noise over the sound of the engine when i go out to look so it can only be heard from inside the car. ive made sure i wasnt being stupid and removed anything from the cabin which could vibrate or make noise etc but it is still there.
any suggestions would be great.
ps the car doesnt have AC if thats of any use to anyone.
thanks
jonny
thanks
jonny
