Clio RS 2006 faults
  Clio RS 197
Hi I have a Clio rs 2006 I got a judder wen I put foot down it won't give the power to u can eney 1 help if u no what it is plz
  renault clio 1.4 16v
Could be coil packs, lambda sensors, injectors, dirty fuel filters, plugs or all of them combined... when last were the fuel filters changed?
Chrisgti6
  Too many
Fuel filter is 144,000 miles and is part of the fuel pump. It's unlikely to be that.
My advice would be not to guess using bits of advice from the internet. Get it looked at by someone with the tools and knowledge to do the job. It WILL save you money in the long run.
You could spend £200 doing plugs, coil, lambda etc but a diag session with a pro is likely to find the problem straight away and fix for less.
