Clio RS 203 headlights problem
  Clio RS mk3
Hi,
I need help considering headlights in my car. The dipped lights stopped working, everything else is fine but only position lights work, even the indicator on the dashboard does. Can you help me locate the problem as both of them stopped working at the same time, bulbs seem ok, same goes with the switch, and I have checked the fuses on the side of the steering wheel as well. Should I check other fuse boxes (if so which one) or the cables?
