Clio speaker cable in door issues!!!
Car  Megane 225
Hi
have bought some crystal speakers for my car and i took the door off and found a purple lead and a grey lead, does anyone know which is positive and which is negative?
Also the speaker has one red lead, and a red and black stripe lead, does anyone know which one would be positive in there?
red lead is pos,red with black stripe is neg,
if you have the use of a multimeter you can test which is pos and neg from the oem loom
be aware of the cable diameter... it may not be suficient for the amp+speakers you are putting
if you look on the plug or the socket on the oem speaker that the plug goes into it should be marked which side is negative
