Clio sport squeak
  Clio 172
Hi I have clio 172 bought it running a misfire turns out firing order was wrong so I got if firing fine but now I have a high pitch squeak sounds like it's coming from throttle today?
I've read it maybe a crack in the cat making it sound like a steam kettle
I did strip alot bk checking all sensors and I moved the butterfly slightly but now I when I start it it sits at 2000 rpm does settle but the noise it still apparent its between 1000 and 3000rpm does anybody have any clue I think maybe it will need calibrating the throttle body but cant explain the noise and help will be great
  PH2 172
Ok I will it's not so loud now sounds like a interference sort of turbo noise
On the assumption that your 172 is a Ph2 with a fly by wire electronic throttle body, it is quite normal for the throttle body to make a constant high pitched zing
when the ignition is switched on, with or without the engine running.
davo172
  TCR'd 172
Hairline crack in the cat makes a whistle on acceleration mine did it for years ?
