clio trip computer
Car  clio
if anyone is having trouble with trip computer to reset it or clear it
1, turn ignition off
2, on wiper stalk theres a button on end hold it in then turn ignition on but dont start
3, this will make your needles on dash move auto leave for a few mins
4, if you want to stop it press in button on cluster the black one
5, this should clear it if not repeat process
Theres a simple diagnostics built into the Mk2 Clio's
To access this, with the igition off press and keep hold of the button at the end of the stalk and turn the ignition on. ALl the dashboard warning lights will come on and the speedo and rev counter will go through a predefined sequene.
When your doing this though (you can let go of the button at the end of the stalk) ever time you press the stalk button the digital readout will show information (listed belew) each time you press the button some more information will show.
All the lights lit (shows if you have a failed LED).
The amount of fuel left in the tank in liters.
Fuel flow (the engine has to be running. This is in liters per hour
Stored faults
t mean an injection fault has been detected for a minimum of 4 seconds
J means a fault has been noted on the fuel gauge. It must have disconnected for longer than 100 seconds. The resistance from the fuel tank sensor needs to be between 5 and 350 Ohms.
d means an injection signal fault has been detected
h means an oil level sensor fault has been detected. Resistance from the sensor should be between 6 and 20 Ohms. Any reading over 20Ohms is an open cicuit anything under 3 is a short circuit.
If no faults are logged then dashes will show fixed dashes.
Press the reset button to clear the logged faults. Other faults arn't shown on the display.
I had a T on mine when i just checked it now.... something to be worried about? cleared it now though, see if it comes up again soon. Car seems to be running great though.
Its nothing much to worry about if you get these warnings just cleaar them and check again even if you have them i woulnd't worry to much there laods of cars with all the warning letters on.
