clio valver MISSFIRING..why?? !!!
Car  clio valver
hey everyone. iv just bought a 1995 clio 1.8 16v with abit of a misfire. the problem is that the spark plug cavities keep filling with water and gettin the plugs and leads wet therefore makin it misfire. so i changed the rocker gasket thinkin it was that and replaced the plugs and leads. after one day of runnin perfect the misfire came back and the cavities were full again ! i was then told it is probly the two core plugs that are sat in between the spark plugs. ive just replaced them also and taken out for a test drive. it was ok for about 5 minutes and the misfire as came back worse than ever ! ive just pulled the plugs out to try for water and they are a little wet but nowhere near as bad as what they were before...but still the missfire. any ideas anyone??
thanks
rob
does your bonnet vent have the rain catcher fitted?
could be any number of things but with the nice weather recently i dont think it will be the vent.
when does it misfire? at idle, mid revs... etc
PFC mag this month lists most common misfire as MAP sensor or throttle body iirc. Although you obviously have a water ingress problem so may not be as applicable.
