clios pulling all over the road!
Car  clio 1.4 dynamique mk2
Hi guys.
I've got an 04 clio dynmamique which I lowered 30mm about a year ago. I haven't had any issue up untill recently.
Within the last few months the car has started pulling quite heavily to the camber of the road!
Now I know all cars to this to some extent, but this feelins quite bad.
The best way I can discribe it is imaginge you're on a dead straight road (wheel straight - 12 o'clock) ant the road cambers to the kerb you'll find you have to point the wheel to say 1 o'clock to drive in a straight line. Likewise if the road cambers to the right, you'll end up pointing it to say 11 o'clock to keep the car straight!
Has anyone had similar problems or any ideas what's causing this?
sounds like play in the streering rack and/or colum to me?? if you had said it happens just one way, i'd of said tracking would be the cause.
toe angles wrong and the tyres have worn and cause this, if you swap the tyres front to back I bet it will be back to normal.
get the tracking sorted.
