clip 1.2 16v miss fire. smoking. flashing eml
Car  clio
03 clio 1.2 16v
100k
Flashing eml
smokes on start up and clear when warm
missfire. On cylinder 3
Changed plug. Changed coil. Swapped injectors about. Cleaned TB. Replaced map sensor..
Compression ok
codes come up with missfire on cylinder and lambda sensor.. but cant seeing above problems being a lambda
Any help
Need to scope the injector and coil trigger but I suspect wiring fault within the top loom section. Buy a new one from Renault if so, around £180
