Clocks stopped : ( Mk1
Ive changed the fuse and checked the connection, both fine. Any ideas, also how do you remove it? Looks like the surround is riveted in?
Its located above the central fan ducts, where the extra gauges are on 16v/Williams?
  Clio 1.8 16v
Hi, if your talking about the 3 clocks in the middle, i think i might be able to help. First remove the top dash, only 5 screws (20 torx). Then from memory i think there are another two or three holding the clocks in. Make sure you have the common earths and feeds (12v) using a multimeter.
Hope this helps...
The clock pushes out.
Im not sure how you do it with the heater controls in though!
PM matbrown cus he might have a spare one!
