Clonk bang ping noise
Clio182mike
  Clio 182
Hello. I have a 182 ff and when I turn off my drive it makes a pinging clonk noise from the front. It sounds like it's coming from the o/s. It drives fine and handles great. I just don't know where to look first? Is there a common issue with the 1*2's?
Rojer
Sounds like a front spring maybe? I would jack the car up take wheels off and give everything a good check over.
d19wood
  Clio 172 T , Megane
You'll be able to see if it's a broken spring easy but if that looks like it's in one piece it might be the top mount
Clio182mike
  Clio 182
I did have a look and the spring is in good condition. Could the top mount need tightening or do they wear out?
Clio_fool
Yep top mount bearing fooked. If it can't rotate freely it basically screws the spring around a bit and the noise you hear is that releasing. Get a pair of new top mounts on there.
