clutch choices on year ?
Car  renault clio 1.8 16v
heres a long long story but dont be put off ! ! ! !
brought this old valver drove ok ish,then wouldnt engage in gear when engine running for a while.
got cable and peddle checked out ok !
changed clutch for a genuine renault one,seem ok but still not changing as it should,smooth
garage suggested that i look and see if there is more than one choice on part as of cross over years etc ?
but the old one was identical to the new one,but not knowing the history of the car was this also changed previous and they also had the wrong clutch ?
please help it wrecking my brains
Clutches are the same
Chnage the clutch cable for an original renault one i bet you have a copy cat one there always rubish and cuase these problems
check the teetch on the clucth pedal as well for any broken ones but clutch cable is the most liky problem
its all been checked still dont know ? it even baffling the garage mech's,all they said the plate is not clearing enough
yeah proper renault clutch cause i got it myself.the cable i cant tell if original or not but i know the pedal mechanism is not a original one but looked identical to the renault one which i snaped.
it goes through the gears lovely but when warmed up it dont want to play ball,no easy to engage
As I said earlier then its the clutch cable they do wear over time and any copy cat one is rubish.
