Ok i was driving down the road yesterday and my car juddered then the clutch went light, so i drove the car home without the aid of the clutch. At home a noticed the tensioner had broke on the top of the pedal so todayi purchased a new pedal for it, after fitting it, it felt ok but wouldnt go in gear easy after a fight it would do making the engine eventually cut out because the clutch was slipping, if you know what i mean. Then a put some washers onto the box end of the cable to tighten it a little but when i pressed the pedal the cable come out of the top of it. any ideas what could be wrong, the cable is only 11 month old and doesnt seem to be strecthed or anything i just put the box on the engine and put the engine in about 2 week ago.
Thanks in advance
Rob
