Clutch problem strugling to get it in to gear
Car  1.8 rsi
My clutch cable snapped the other day had it replaced and it was fine the biting point was also very low and hard to get in to gear but foot to the floor and it will work the clutch was also sliping when i brought the car so i replaced the clutch yesterday and now i really have to push the clutch pedal as far as i can to the floor to get it in to gear and usually u get a bit of a grind its as if the cable is to long and not pulling the clutch out far enought to get it in to gear i wonderd if the self adjuster on the pedal would do this if it is broke cheers dale
The ratchet mechanism on the pedal end may need re-setting mate, from memory, i can't remember, its about 5 years since i did one! Get under the pedal box and investigate! Should be pretty easy to see whats going on!!
