Hi All,
Had the clutch replaced on my 172 p2 yesterday using an Exedy OEM replacement clutch kit as the clutch release bearing had died. As part of this the flywheel was also machined.
When going to pick the car up, the mechanic said he was concerned about the clutch but fitted it anyway... and said something about the pressure plate. Now when I depress the clutch its perfectly fine and quiet until ~90-95% depressed, when it makes a nasty little grinding noise.
The clutch is fully released by ~85% depression (before the noise starts)
The mechanic is trying to tell me I shouldn't worry, something about the thick new clutch causing something with the pressure plate (didn't quite catch his explanation). Mentioned that the non-adjustable clutch cable of the Clio's had something to do with it.
Also of note, the clutch is a TON lighter than it used to be... if that helps.
Anyone able to clear up what this may be, because it certainly sounds fishy to me?
