clutch squeek
Car  172 cup track/road
hya all, i originaly thaught it was a squeeky fan belt, but after some investigation its coming from the clutch when i press it down, even what when not moving and in neutrel. any idea what it is and is it a easy fix.
Think there is fix in the guides section iirc.
its not the squeak that you get from the pedal its actualy coming from the engine or clutch, bit like when u press the clutch and you get thrust bearing noise. when u press the clutch all the way in and keep it there it does it at its worst then. iv never heard come across it before on another car.
