clutch stiff
hi everyone my clutch after some time especially in town goes very very stiff which makes hard to pull away or for a racing start what could this be i had my clutch checked by renault and they said it was fine does it need lubricating like the cable or smething cheers
Martin_172
worth changing the cable, i changed my clutch and it got twice as light as it previously was, then when i changed the cable it once again got twice as light, its brilliant now never driven a clio with a clutch as light as mine!
was only about £30 for the cable i think
cheers for that might is that what is causing the stiffness the cable? how many hours to fit the cable cheers
ohi see have you got a pic of where i can lubriate mate sorry but i am useless with car i can polish and clean them well though he he
  Lots of Alfas
Which clio is it, you cant miss it really its on the front of the gearbox. There is a black arm and a cable attached but dont go spraying wd40 in the clutch. Get someone to sit in the car and press the clutch and watch it move.
hi mate its a mk2 172 i really dont know where anything is have you got a pic mate or easy directions to it if i am stud in front of the car cheers
If your not happy with where bits are then get a garages to chnage the cable its a pain to do on the 172 anyway.
hi guys the car has covered 57k the clutch was checked by renault and they said it was ok its just the pedal gets very stiff which makes pulling away and clutch control very hard!!! how much does it cost to change the cable? cheers
Depends how muc the garage charge I'd say 45 minutes labour so most lily 1 hours chagr so anywhere from £30 to £90.
cheers mate do you think the cable is a safe bet mate cos as i said before the clutch has been tested as being ok??
