I'm convinced my clutch is not disengaging (is that the correct word) enough when i press the clutch pedal, i know these are cable operated and self adjusting, but is the anyway of manually adjusting the cable to?
Have a look at the pedal ratchet system and you'll see the problem assuming its not broken(common Mk1 problem) then you'll see its not adjustable realty
I take it you have a standard Renault cable as aftermarket ones are rubish.
you could always put spacers in the clutch fork bit but you shoulnd't need to ever.
