KitsonRis
Didn't use my car this weekend as I was away. It rained, foot well full of water (again) - now think this is a blocked drain plug in the wiper scutter as first thought I left my winder open. Then the car sounded like it was on 3 cylinders and then struggled and the engine management light was flashing at me. Then I am sure it was firing on 3 cylinders. Pulled over after about 3 miles of driving. Did the turn off/on again and was still doing it.
Then all of a sudden the car pulled away fine, sounded normal and the engine management light is now constant on. Car seems to be fine now, but I want to find out why.
Also the revs seem to be stuck at 2k when idle unless I blip the throttle and it drops to normal. Is this something to do with the fault or the sticky throttle problem with a Ph1?
Not sure if the rain has anything to do with it and a little drive has solved it and dryed it out. And the light is constant on now until I clear the fault??
It had an oil change the other week. Spark plugs were done a few months back (nice NGK ones). But I haven't done the coil pack. Car has done 165k miles.
