clio 172
I will be fitting my coilovers in 2 weeks. ive purchased kw variant 2.
Will i need to get upgrade topmounts, also which brand and where from ?
also will i need to get anythink of the existing suspension struts ? just so i know if i need to get hold of a set of spring compressors.
im also going to fit new discs and pads front and rear while im at it.
when you replace the rear discs dont you need to put new bearings in ?
where do you buy the rear disc bearings from seen some discs but will have to get the bearings.
also what pads for general use ?will be buying some track pads later on in the year.
cheers
finch
cheers
finch
