Coilover help?
Depends if your planning on getting air.
If the rear beam drops the springs WILL pop out quite easily, depending on the size of the rear springs.
Yes, very easy, jack up, one bolt underneath either side and done.
I did it on mine and had no problems. I used the standard rubber bits that hold the standard springs in place instead of adjusters etc.
