Coilover seized
Car  Clio 172 rep
Any ideas how to unseize it while there still on the car?? Need to go lower but there seized :( got about another 2 inches
give the threads a good clean up to try and remove as much s**t as possible (an old toothbrush works well) and spray some WD-40 over them and letting them soak for a while.
Hmmmm ill give them a good clean next time ive got my wheels off and plaster them in wd40 then if get nuthink from that ill take them off and let them soak for a day or twoo
if soaking in wd40 does not work, other option is lots of heat
​failing that i had to cut mine off :( and buy new rings
Thankss ladss much apreciateedd will try all of the above if non works looks like its a cut off and get new rings :(
Take it off, put it in a bucket of cheap full fat coke overnight, wash down and profit.
