colour coding DIY style
Car  Clio 1.2+ Laguna 2.0
im in the process of spraying my side moulding black, to match the car, should i use the plastic grey primer before spraying the black??
Don't spray to close to the object. Sweep or 'brush' along it rather than aiming at just one area.
Just to prevent any thick build up that could cause run lines.
Test spray the nozzle away from the object before moving over to it. Get an idea of how the paint is coming out the can etc.
on textured plastics, rub it down as smooth as possible. 1st coat use a plastic primer, then additional layers use a filler / high build primer to further help leave a smooth fiish for applying colour
