took it back to jabba today to try to sort the knocking/rattling out. after 45mins... still no result. they are still knocking! we made up some metal washers to go between the top locking nut and the rubber washer to allow the top nut to be tightened up more. still no luck tho
does anyone else get a lot of knocking/rattling from their solid top mounts??! (and i don't just mean more road noise)
i had this. they are a bad design in that they dont fit the bottom of the turret, they move about about 1cm in the turret, which is bad as potholes etc jolt them over which changes the camber and castor....
mine had been moving about a while (had a gut feeling it was moving about and was right) and tried to remove them but the lock rings had both jammed solid (i assume from where its ovalled moving about)
in the end i ruined them tightenging them up with an air chisel as a temp measure.
when i get a chance im going to cut the lock rings off and drill and tap them and bolt them to the turret
