182 Trophy
Hi all,
I'm sure this has been asked several times but despite searching for a good while I can't seem to find a answer. I've recently bought a 182 Trophy and I'm working through servicing it - just got coolant and brake fluid left to do. It's currently got red coolant in of unknown origin (I believe it was done at a Renault garage). I've bought the proper Renault Type D stuff to replace it and want to flush out all the old stuff to be on the safe side.
Ideally I don't want to take the thermostat out if I can help it as it's working fine and I don't have a new gasket on hand. The last time I replaced a thermostat it was a complete pain getting the housing itsself to seal up again.
Will removing the lower rad hose drain the block or is there a separate drain for that anywhere? I'm guessing the other option is to drain through the lower rad hose, fill up with water and run it up to temp (opening the thermostat and mixing it all up), letting it cool and draining again until it runs clear. Though how much water does the block hold? Don't want to dilute it too much if I can help it as I'm using pre-mixed.
Cheers.
Cheers.
